Introducción
This simple guide will show you how to remove the two speakers from a Lenovo Yoga 710-14KB.
  1. Use a Torx T4 screwdriver to unscrew the 9 5mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 9 5mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover. The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard. The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Use the Phillips #00 screwdriver to remove the four 3mm screws holding the battery in place. Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
    • Use the Phillips #00 screwdriver to remove the four 3mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
  5. Use the blue plastic opening tool to disconnect the battery cable. Make sure to apply pressure upward and try not to wiggle the connector from side to side, as this could damage the connector. Make sure to apply pressure upward and try not to wiggle the connector from side to side, as this could damage the connector.
    • Use the blue plastic opening tool to disconnect the battery cable.
    • Make sure to apply pressure upward and try not to wiggle the connector from side to side, as this could damage the connector.
  6. Locate the speaker's plug and disconnect it.
    • Locate the speaker's plug and disconnect it.
    • Follow the wires connected to the plug to locate the speakers. The left speaker will have red wires, and the right speaker will have blue wires.
  7. Untangle the wires from the plastic hinges of the case to properly lift the speakers out. Untangle the wires from the plastic hinges of the case to properly lift the speakers out.
    • Untangle the wires from the plastic hinges of the case to properly lift the speakers out.
Conclusión
Bailey Murphy
Miembro Desde 01/11/18
85 Reputación
1 Guía escrita
Equipo
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 4
Todo El Tiempo: 48
