Saltar al contenido principal
Lenovo Yoga 710-14IKB SSD Replacement
Qué necesitas
  1. Lenovo Yoga 710-14IKB SSD Replacement, Back Cover: paso 1, imagen 1 de 1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB SSD Replacement: paso 2, imagen 1 de 3 Lenovo Yoga 710-14IKB SSD Replacement: paso 2, imagen 2 de 3 Lenovo Yoga 710-14IKB SSD Replacement: paso 2, imagen 3 de 3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB SSD Replacement, SSD: paso 3, imagen 1 de 2 Lenovo Yoga 710-14IKB SSD Replacement, SSD: paso 3, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the 3mm screw on the SSD.
  4. Lenovo Yoga 710-14IKB SSD Replacement: paso 4, imagen 1 de 2 Lenovo Yoga 710-14IKB SSD Replacement: paso 4, imagen 2 de 2
    • Use your fingers to lift up the SSD and pull away from the socket removing it from the laptop.
Conclusión
7 personas más completaron esta guía.
Grant Doerksen
Miembro Desde 04/17/17
1,005 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S14-G5, Banghart Spring 2017 Miembro de Cal Poly, Team S14-G5, Banghart Spring 2017
CPSU-BANGHART-S17S14G5
4 Miembros
21 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 25
Ultimos 30 días: 62
Todo El Tiempo: 11,239
