Introducción
This simple guide will show you how to unscrew and remove all cables from the motherboard of a Lenovo Yoga 710-14KB besides the display cable, which will need to be unsoldered.
Qué necesitas
Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
3 personas más completaron esta guía.
