Introducción
This simple guide will show you how to unscrew and remove all cables from the motherboard of a Lenovo Yoga 710-14KB besides the display cable, which will need to be unsoldered.
  1. Use a Torx T4 screwdriver to unscrew the 9 5mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 9 5mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
    • Use the Phillips #00 screwdriver to remove the four 3mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
    • Use the blue plastic opening tool to disconnect the battery cable.
    • Make sure to apply pressure upward and try not to wiggle the connector from side to side, as this could damage the connector.
    • Use a Phillips #00 screwdriver to remove the 3mm screw on the SSD.
    • Use your fingers to lift up the SSD and pull away from the socket removing it from the laptop.
    • Use a PH00 screwdriver to remove the nine 3mm screws.
    • Disconnect the indicated cables from the motherboard.
    • Be careful when removing cables. Do not pull or yank cables from their slots.
    • Remove the motherboard.
    • If you want to fully remove the motherboard, you must desolder the display cable.
Conclusión
Evan Cruzen
Miembro Desde 01/11/18
181 Reputación
2 Guías creadas
Equipo
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 20
Últimos 30 Días: 57
Todo El Tiempo: 89
