Introducción
If your device isn’t properly loading or is slow to load files, the SSD may be corrupt. Follow these instructions to replace the SSD in your Lenovo Yoga 710-11ISK.
Qué necesitas
Make sure back panel is facing up.
Remove eleven 5mm screws with the T5 Torx Screwdriver.
Use a Phillips #00 screwdriver to remove the single 3 mm screw on the right of the SSD.
Casi Terminas!
Conclusión
