Introducción
This guide will show you how to replace the wifi card. As an extra precaution, the battery should be removed first before proceeding with the rest of the device.
Qué necesitas
Flip the laptop so that the back panel is facing up.
Remove the ten 4.0mm T6 Torx screws from the back of the laptop.
Using the plastic opening tool, gently pry the grey wire off the wifi card.
Pry the black wire off the wifi card.
2 personas más completaron esta guía.
