Saltar al contenido principal
Lenovo Yoga 3 Pro Motherboard Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Lenovo Yoga 3 Pro Motherboard Replacement, Back Panel: paso 1, imagen 1 de 2 Lenovo Yoga 3 Pro Motherboard Replacement, Back Panel: paso 1, imagen 2 de 2
    • Flip the laptop so that the back panel is facing up.
    • Remove the ten 4.0mm T6 Torx screws from the back of the laptop.
  2. Lenovo Yoga 3 Pro Motherboard Replacement: paso 2, imagen 1 de 1
    • Gently lift the back cover off of the laptop.
  3. Lenovo Yoga 3 Pro Motherboard Replacement, Battery: paso 3, imagen 1 de 2 Lenovo Yoga 3 Pro Motherboard Replacement, Battery: paso 3, imagen 2 de 2
    • Push the black battery cable towards the battery to disconnect it.
  4. Lenovo Yoga 3 Pro Motherboard Replacement: paso 4, imagen 1 de 2 Lenovo Yoga 3 Pro Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove the six #0 3.8mm Phillips screws from the battery.
  5. Lenovo Yoga 3 Pro Motherboard Replacement: paso 5, imagen 1 de 1
    • Gently lift the battery out of the laptop chassis.
  6. Lenovo Yoga 3 Pro Motherboard Replacement, Wireless Card: paso 6, imagen 1 de 2 Lenovo Yoga 3 Pro Motherboard Replacement, Wireless Card: paso 6, imagen 2 de 2
    • Using the plastic opening tool, gently pry the grey wire off the wifi card.
    • Pry the black wire off the wifi card.
  7. Lenovo Yoga 3 Pro Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the one #0 2.9mm Phillips screw from the base of the wifi card.
  8. Lenovo Yoga 3 Pro Motherboard Replacement: paso 8, imagen 1 de 2 Lenovo Yoga 3 Pro Motherboard Replacement: paso 8, imagen 2 de 2
    • Gently lift and pull the wifi card out.
  9. Lenovo Yoga 3 Pro Motherboard Replacement, SSD: paso 9, imagen 1 de 2 Lenovo Yoga 3 Pro Motherboard Replacement, SSD: paso 9, imagen 2 de 2
    • Remove the one #0 2.9mm Phillips screw from the SSD.
  10. Lenovo Yoga 3 Pro Motherboard Replacement: paso 10, imagen 1 de 1
    • Gently lift and wiggle the SSD side to side to remove it from the laptop chassis.
  11. Lenovo Yoga 3 Pro Motherboard Replacement, Motherboard: paso 11, imagen 1 de 3 Lenovo Yoga 3 Pro Motherboard Replacement, Motherboard: paso 11, imagen 2 de 3 Lenovo Yoga 3 Pro Motherboard Replacement, Motherboard: paso 11, imagen 3 de 3
    • Push the cable away from the motherboard.
  12. Lenovo Yoga 3 Pro Motherboard Replacement: paso 12, imagen 1 de 3 Lenovo Yoga 3 Pro Motherboard Replacement: paso 12, imagen 2 de 3 Lenovo Yoga 3 Pro Motherboard Replacement: paso 12, imagen 3 de 3
    • Remove the two #0 2.9mm Phillips screws from the daughter board.
  13. Lenovo Yoga 3 Pro Motherboard Replacement: paso 13, imagen 1 de 1
    • Lift the daughter board with the plastic opening tool.
    • You will hear two clicks when lifting the daughter board.
  14. Lenovo Yoga 3 Pro Motherboard Replacement: paso 14, imagen 1 de 3 Lenovo Yoga 3 Pro Motherboard Replacement: paso 14, imagen 2 de 3 Lenovo Yoga 3 Pro Motherboard Replacement: paso 14, imagen 3 de 3
    • Lift the daughter board, unrouting the wireless cables from their plastic holders, and place it to the side.
  15. Lenovo Yoga 3 Pro Motherboard Replacement: paso 15, imagen 1 de 3 Lenovo Yoga 3 Pro Motherboard Replacement: paso 15, imagen 2 de 3 Lenovo Yoga 3 Pro Motherboard Replacement: paso 15, imagen 3 de 3
    • Gently lift the metal tabs on the daughter board to free the wires.
  16. Lenovo Yoga 3 Pro Motherboard Replacement: paso 16, imagen 1 de 3 Lenovo Yoga 3 Pro Motherboard Replacement: paso 16, imagen 2 de 3 Lenovo Yoga 3 Pro Motherboard Replacement: paso 16, imagen 3 de 3
    • Detach the five flat flex cables attached to the motherboard as follows:
    • 1. Flip the cable holder up with a finger nail
    • 2. Pull on the tab to remove the cable.
    • The large black flat flex labeled 'MB' does not have a tab so gently tug the cable free from the end after flipping the cable holder.
  17. Lenovo Yoga 3 Pro Motherboard Replacement: paso 17, imagen 1 de 3 Lenovo Yoga 3 Pro Motherboard Replacement: paso 17, imagen 2 de 3 Lenovo Yoga 3 Pro Motherboard Replacement: paso 17, imagen 3 de 3
    • Remove the four #0 2.3mm Phillips screws holding down the motherboard.
    • Remove the two #0 2.9mm Phillips screws holding down the fan.
  18. Lenovo Yoga 3 Pro Motherboard Replacement: paso 18, imagen 1 de 3 Lenovo Yoga 3 Pro Motherboard Replacement: paso 18, imagen 2 de 3 Lenovo Yoga 3 Pro Motherboard Replacement: paso 18, imagen 3 de 3
    • Make sure the motherboard and fan are not caught on anything when flipping it over.
    • Gently lift and flip the motherboard over.
  19. Lenovo Yoga 3 Pro Motherboard Replacement: paso 19, imagen 1 de 3 Lenovo Yoga 3 Pro Motherboard Replacement: paso 19, imagen 2 de 3 Lenovo Yoga 3 Pro Motherboard Replacement: paso 19, imagen 3 de 3
    • Flip the cable lock holding down the monitor connector.
    • Remove the monitor connector by tugging on the tab.
Conclusión
5 personas más completaron esta guía.
Nathan Lui
Miembro Desde 04/10/17
839 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S13-G6, Forte Spring 2017 Miembro de Cal Poly, Team S13-G6, Forte Spring 2017
CPSU-FORTE-S17S13G6
4 Miembros
12 Guías creadas
2 comentarios
There is a tremendous difference between this model and the lenovo yoga 4 900-13ISK.
These instructions do not apply, but some steps are similar
corey - Contestar
Hi. Do you have any idea where I could by a replacement motherboard and how much that would cost? Please answer to martin.loffler@gmail.com. Thank you so much. Best, Martin
Martin Loffler - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 49
Todo El Tiempo: 7,629
