Saltar al contenido principal
Lenovo Yoga 3 14 USB Port Replacement
Qué necesitas
  1. Lenovo Yoga 3 14 USB Port Replacement, Back Case: paso 1, imagen 1 de 1
    • Remove the eleven 6mm T5 Torx screws from the back case.
  2. Lenovo Yoga 3 14 USB Port Replacement: paso 2, imagen 1 de 3 Lenovo Yoga 3 14 USB Port Replacement: paso 2, imagen 2 de 3 Lenovo Yoga 3 14 USB Port Replacement: paso 2, imagen 3 de 3
    • Insert the plastic opening tool into the long side of the case backing and slide it the entire length of the laptop.
    • Gently lift the backing off the laptop.
  3. Lenovo Yoga 3 14 USB Port Replacement, Battery: paso 3, imagen 1 de 1
    • Remove the four 3mm PH#0 screws surrounding the battery.
  4. Lenovo Yoga 3 14 USB Port Replacement: paso 4, imagen 1 de 3 Lenovo Yoga 3 14 USB Port Replacement: paso 4, imagen 2 de 3 Lenovo Yoga 3 14 USB Port Replacement: paso 4, imagen 3 de 3
    • Gently lift the battery and use the plastic opening tool to remove the battery's connection to the laptop.
  5. Lenovo Yoga 3 14 USB Port Replacement, USB Port: paso 5, imagen 1 de 2 Lenovo Yoga 3 14 USB Port Replacement, USB Port: paso 5, imagen 2 de 2
    • Take out the 3, 3mm screws from the left hinge using the PH0 head.
    • Remove the 1, 4mm screw that connects the hinge to the USB port.
    • Carefully lift the hinge enough to separate it from the USB port.
  6. Lenovo Yoga 3 14 USB Port Replacement: paso 6, imagen 1 de 2 Lenovo Yoga 3 14 USB Port Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using the tweezers, carefully lift the black clip and remove the electrical ribbon.
  7. Lenovo Yoga 3 14 USB Port Replacement: paso 7, imagen 1 de 1
    • The USB port is held in place by plastic pegs. Gently lift up to remove the USB port from the laptop.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team 3-2, Passmore Fall 2016 Miembro de USF Tampa, Team 3-2, Passmore Fall 2016
USFT-PASSMORE-F16S3G2
4 Miembros
7 Guías creadas
2 comentarios
Anyone know where I can buy this part? Cannot find it anywhere…
Nicolas Petersen - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 2,136
