Saltar al contenido principal
Lenovo Yoga 3 14 Speaker Replacement
Qué necesitas
  1. Lenovo Yoga 3 14 Speaker Replacement, Back Case: paso 1, imagen 1 de 1
    • Remove the eleven 6mm T5 Torx screws from the back case.
  2. Lenovo Yoga 3 14 Speaker Replacement: paso 2, imagen 1 de 3 Lenovo Yoga 3 14 Speaker Replacement: paso 2, imagen 2 de 3 Lenovo Yoga 3 14 Speaker Replacement: paso 2, imagen 3 de 3
    • Insert the plastic opening tool into the long side of the case backing and slide it the entire length of the laptop.
    • Gently lift the backing off the laptop.
  3. Lenovo Yoga 3 14 Speaker Replacement, Battery: paso 3, imagen 1 de 1
    • Remove the four 3mm PH#0 screws surrounding the battery.
  4. Lenovo Yoga 3 14 Speaker Replacement: paso 4, imagen 1 de 3 Lenovo Yoga 3 14 Speaker Replacement: paso 4, imagen 2 de 3 Lenovo Yoga 3 14 Speaker Replacement: paso 4, imagen 3 de 3
    • Gently lift the battery and use the plastic opening tool to remove the battery's connection to the laptop.
  5. Lenovo Yoga 3 14 Speaker Replacement, Speaker: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using a pair of tweezers, dissconnect the speakers on the left side of the laptop.
  6. Lenovo Yoga 3 14 Speaker Replacement: paso 6, imagen 1 de 2 Lenovo Yoga 3 14 Speaker Replacement: paso 6, imagen 2 de 2
    • Flip up the black retaining flap on the ZIF connector.
    • Using tweezers, gently disconnect the blue strip that connects the touch pad to the motherboard.
  7. Lenovo Yoga 3 14 Speaker Replacement: paso 7, imagen 1 de 2 Lenovo Yoga 3 14 Speaker Replacement: paso 7, imagen 2 de 2
    • Use tweezers to gently pull off tape that is holding down wires that are connecting the two speakers together.
  8. Lenovo Yoga 3 14 Speaker Replacement: paso 8, imagen 1 de 2 Lenovo Yoga 3 14 Speaker Replacement: paso 8, imagen 2 de 2
    • Both speakers are held in place by plastic pegs. Gently lift the speakers off the casing to remove them.
  9. Lenovo Yoga 3 14 Speaker Replacement: paso 9, imagen 1 de 2 Lenovo Yoga 3 14 Speaker Replacement: paso 9, imagen 2 de 2
    • Simply grip the speaker wires and lift away from laptop to remove.
Conclusión
Equipo
USF Tampa, Team 3-2, Passmore Fall 2016 Miembro de USF Tampa, Team 3-2, Passmore Fall 2016
USFT-PASSMORE-F16S3G2
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 1,268
