Saltar al contenido principal
Introducción
If you are experiencing low to no sound coming from the speaker even when the volume is turned all the way up, then you have come to the right place as your speaker may need to be replaced. This guide will help you achieve the removal and replacement of your speaker.
  1. Lenovo Yoga 3 11 Speaker Replacement, Lower Case: paso 1, imagen 1 de 1
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 Speaker Replacement, Battery: paso 2, imagen 1 de 3 Lenovo Yoga 3 11 Speaker Replacement, Battery: paso 2, imagen 2 de 3 Lenovo Yoga 3 11 Speaker Replacement, Battery: paso 2, imagen 3 de 3
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Lenovo Yoga 3 11 Speaker Replacement: paso 3, imagen 1 de 1
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Lenovo Yoga 3 11 Speaker Replacement: paso 4, imagen 1 de 2 Lenovo Yoga 3 11 Speaker Replacement: paso 4, imagen 2 de 2
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  5. Lenovo Yoga 3 11 Speaker Replacement: paso 5, imagen 1 de 1
    • Carefully remove the battery from the device.
  6. Lenovo Yoga 3 11 Speaker Replacement, Speaker: paso 6, imagen 1 de 2 Lenovo Yoga 3 11 Speaker Replacement, Speaker: paso 6, imagen 2 de 2
    • Use a pair of tweezers to peel up one side of each of the 3 pieces of tape that cover the speaker wires.
  7. Lenovo Yoga 3 11 Speaker Replacement: paso 7, imagen 1 de 2 Lenovo Yoga 3 11 Speaker Replacement: paso 7, imagen 2 de 2
    • Use a pair of tweezers to disconnect the ZIF connector securing the trackpad ribbon cable. Gently lift the black tab up, and the cable should come free.
  8. Lenovo Yoga 3 11 Speaker Replacement: paso 8, imagen 1 de 3 Lenovo Yoga 3 11 Speaker Replacement: paso 8, imagen 2 de 3 Lenovo Yoga 3 11 Speaker Replacement: paso 8, imagen 3 de 3
    • Remove the two 2 mm Phillips #0 screws securing the left speaker.
    • Remove the two 2 mm Phillips #0 screws securing the right speaker.
  9. Lenovo Yoga 3 11 Speaker Replacement: paso 9, imagen 1 de 2 Lenovo Yoga 3 11 Speaker Replacement: paso 9, imagen 2 de 2
    • Use a pair of tweezers to disconnect the speaker connector.
    • Gently lift the speakers free of the device.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 2-3, Blackwell Fall 2015 Miembro de USF Tampa, Team 2-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G3
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 1,070
