Saltar al contenido principal
Lenovo Yoga 3 11 Screen Replacement
Qué necesitas
  1. Lenovo Yoga 3 11 Screen Replacement, Screen: paso 1, imagen 1 de 2 Lenovo Yoga 3 11 Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Use a plastic opening tool or the pointed end of a spudger to pry up the 2 rubber inserts in the bottom left and right corners of the screen.
  2. Lenovo Yoga 3 11 Screen Replacement: paso 2, imagen 1 de 1
    • Remove the single silver 5 mm screw found beneath each rubber insert.
  3. Lenovo Yoga 3 11 Screen Replacement: paso 3, imagen 1 de 2 Lenovo Yoga 3 11 Screen Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool to pry off the three plastic trim pieces.
  4. Lenovo Yoga 3 11 Screen Replacement: paso 4, imagen 1 de 2 Lenovo Yoga 3 11 Screen Replacement: paso 4, imagen 2 de 2
    • Work the plastic opening tool in between bezel and the upper case.
    • Once the plastic opening tool is wedged in between the two, work the plastic opening tool around the perimeter of the screen, separating the bezel from the display.
  5. Lenovo Yoga 3 11 Screen Replacement: paso 5, imagen 1 de 1
    • Use the tweezers to unplug the screen connector in the middle.
  6. Lenovo Yoga 3 11 Screen Replacement: paso 6, imagen 1 de 2 Lenovo Yoga 3 11 Screen Replacement: paso 6, imagen 2 de 2
    • Use the tweezers to pull the tape upwards. The tape will pull the wires up with it, separating the connection.
  7. Lenovo Yoga 3 11 Screen Replacement: paso 7, imagen 1 de 1
    • Use the tweezers to follow the wires and move them out from under the plastic hooks.
  8. Lenovo Yoga 3 11 Screen Replacement: paso 8, imagen 1 de 1
    • Use the tweezers to unplug the connector near the top of the screen.
  9. Lenovo Yoga 3 11 Screen Replacement: paso 9, imagen 1 de 1
    • Use the tweezers to pull the tape upwards in order to free the wires underneath it.
  10. Lenovo Yoga 3 11 Screen Replacement: paso 10, imagen 1 de 1
    • Use the tweezers to pull up the camera by simply pulling upwards on the tape that is over it.
  11. Lenovo Yoga 3 11 Screen Replacement: paso 11, imagen 1 de 1
    • Use the tweezers to follow the wires and to pull them out from under the plastic black hooks. Also pull up any tape that is over the wires.
  12. Lenovo Yoga 3 11 Screen Replacement: paso 12, imagen 1 de 3 Lenovo Yoga 3 11 Screen Replacement: paso 12, imagen 2 de 3 Lenovo Yoga 3 11 Screen Replacement: paso 12, imagen 3 de 3
    • Use the plastic opening tool to work the black component up and out of its original spot, then pull out the following connected wires.
  13. Lenovo Yoga 3 11 Screen Replacement: paso 13, imagen 1 de 1
    • Use the tweezers to unplug the black connection near the hinge of the laptop, taking the yellow tape off with it.
  14. Lenovo Yoga 3 11 Screen Replacement: paso 14, imagen 1 de 1
    • Gently lift and remove the screen for replacing.
Conclusión
Una persona más ha completado esta guía.
Miles Davis
Miembro Desde 08/27/15
131 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 2-3, Blackwell Fall 2015 Miembro de USF Tampa, Team 2-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G3
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 874
