Saltar al contenido principal
Lenovo Yoga 2 Pro Wireless Card Replacement
Qué necesitas
  1. Lenovo Yoga 2 Pro Wireless Card Replacement, Wireless Card: paso 1, imagen 1 de 1
    • Please ensure that the laptop is turned off before beginning.
    • Using a T5 Torx screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  2. Lenovo Yoga 2 Pro Wireless Card Replacement: paso 2, imagen 1 de 1
    • Gently lift off the back cover.
  3. Lenovo Yoga 2 Pro Wireless Card Replacement: paso 3, imagen 1 de 1
    • Locate the wireless module above the battery in the top left corner of the computer.
    • Using a spudger, disconnect the two metal connectors by popping the metal piece up from the wireless module.
  4. Lenovo Yoga 2 Pro Wireless Card Replacement: paso 4, imagen 1 de 1
    • Remove the one 1/16” screw using a Phillips #00 screwdriver.
  5. Lenovo Yoga 2 Pro Wireless Card Replacement: paso 5, imagen 1 de 2 Lenovo Yoga 2 Pro Wireless Card Replacement: paso 5, imagen 2 de 2
    • Slide the wireless module towards the battery and lift out of the laptop.
Conclusión
9 personas más completaron esta guía.
Thomas Simko
Miembro Desde 10/01/15
2,531 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 12-14, Maness Fall 2015 Miembro de Cal Poly, Team 12-14, Maness Fall 2015
CPSU-MANESS-F15S12G14
5 Miembros
12 Guías creadas
2 comentarios
Be careful, there is a very restrictive Whitelist in the BIOS for potential replacements, unofficial support available via their forums;
(tl;dr - go with Intel AC 7260 - m.2 connection)
https://forums.lenovo.com/t5/Lenovo-Yoga...
Jamie Haustead - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 11,280
