Saltar al contenido principal
Lenovo Yoga 2 Pro Trackpad Replacement
Qué necesitas
  1. Lenovo Yoga 2 Pro Trackpad Replacement, Battery: paso 1, imagen 1 de 1
    • Please ensure that the laptop is turned off before beginning.
    • Using a Phillips #00 screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  2. Lenovo Yoga 2 Pro Trackpad Replacement: paso 2, imagen 1 de 1
    • Gently unclip and lift off the back cover.
  3. Lenovo Yoga 2 Pro Trackpad Replacement: paso 3, imagen 1 de 1
    • Using a Phillips #00 Screwdriver, remove the five 5/16" screws surrounding the battery.
  4. Lenovo Yoga 2 Pro Trackpad Replacement: paso 4, imagen 1 de 1
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  5. Lenovo Yoga 2 Pro Trackpad Replacement: paso 5, imagen 1 de 2 Lenovo Yoga 2 Pro Trackpad Replacement: paso 5, imagen 2 de 2
    • Remove the battery from the computer.
  6. Lenovo Yoga 2 Pro Trackpad Replacement, Trackpad: paso 6, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the eight 1/8" screws surrounding the trackpad.
  7. Lenovo Yoga 2 Pro Trackpad Replacement: paso 7, imagen 1 de 1
    • Using a sharp tool such as tweezers, lift up the black cover that is on top of the ribbon cable.
  8. Lenovo Yoga 2 Pro Trackpad Replacement: paso 8, imagen 1 de 1
    • With tweezers, gently slide the ribbon cable out from under the connector.
  9. Lenovo Yoga 2 Pro Trackpad Replacement: paso 9, imagen 1 de 2 Lenovo Yoga 2 Pro Trackpad Replacement: paso 9, imagen 2 de 2
    • Lift the trackpad out of the computer.
Conclusión
6 personas más completaron esta guía.
Thomas Simko
Miembro Desde 10/01/15
2,511 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 12-14, Maness Fall 2015 Miembro de Cal Poly, Team 12-14, Maness Fall 2015
CPSU-MANESS-F15S12G14
5 Miembros
12 Guías creadas
3 comentarios
Where can I buy this trackpad? Mine is done.
Jorge Suarez - Contestar
Same here. Where can I buy the part? I cannot even find a part number.
iwaniec - Contestar
I got a lot of different options on ebay but cannot rely on them. I think we could order it from IBM FRU parts but only by email or phone at:
https://www-304.ibm.com/shop/americas/co...
FRU: 73040855
Will try tomorrow
LUIS GARZA - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 20
Todo El Tiempo: 9,403
