Saltar al contenido principal
Lenovo Yoga 2 13" Fan Replacement
Qué necesitas
  1. Lenovo Yoga 2 13" Fan Replacement, Back Panel: paso 1, imagen 1 de 1
    • Be sure to power off and unplug your device before you begin your repair.
    • With a T5 Torx screwdriver, remove eleven 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 13" Fan Replacement: paso 2, imagen 1 de 1
    • Carefully separate back panel from the laptop.
  3. Lenovo Yoga 2 13" Fan Replacement, Fan: paso 3, imagen 1 de 1
    • Locate the fan near the top of the laptop.
  4. Lenovo Yoga 2 13" Fan Replacement: paso 4, imagen 1 de 1
    • Carefully unscrew three 2.381mm screws using a Phillips head screwdriver.
  5. Lenovo Yoga 2 13" Fan Replacement: paso 5, imagen 1 de 1
    • The fan is attatched to four wires and a white clip. Carefully slide the clip out of the yellow port to completely remove the fan.
Conclusión
13 personas más completaron esta guía.
Nichelle
Miembro Desde 03/11/15
1,550 Reputación
5 Guías creadas
Equipo
Marist, Team 1-2, Laflen Spring 2015 Miembro de Marist, Team 1-2, Laflen Spring 2015
MARS-LAFLEN-S15S1G2
3 Miembros
7 Guías creadas
3 comentarios
Anyone know where I can buy a replacement fan? I'm having a hard time finding the correct model. I have a first generation Thinkpad Yoga.
Daniel Shen - Contestar
where can i find a new fan for lenovo yoga 2 13
peter trevisan - Contestar
where can i find a new lenovo yoga 2 13?
Han Altae-Tran - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 19
Todo El Tiempo: 14,090
