Introducción
As time passes, a battery loses its capability to hold a single charge. This guide will aide users in removing the back panel to reach and replace the faulty battery. Remember to turn the laptop off prior to the repair.
Qué necesitas
With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
Once you have completed the prerequisite guide, locate the battery of the laptop. Remember to disconnect the battery.
12 personas más completaron esta guía.
4 comentarios
how do I remove unathorized battery error?
POOR INSTRUCTIONS
You have failed to mention that the battery cable is attached by a clip that requires opening.
Terrible.
You just took pictures of unscrewing. Not Useful.
