Saltar al contenido principal
Lenovo Yoga 2 11" Back Panel Replacement
Qué necesitas
  1. Lenovo Yoga 2 11" Back Panel Replacement, Back Panel: paso 1, imagen 1 de 1
    • With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 11" Back Panel Replacement: paso 2, imagen 1 de 1
    • Carefully separate back panel from laptop.
Conclusión
3 personas más completaron esta guía.
Peyton Leeson
Miembro Desde 10/01/15
939 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 4-3, Maness Fall 2015 Miembro de Cal Poly, Team 4-3, Maness Fall 2015
CPSU-MANESS-F15S4G3
4 Miembros
5 Guías creadas
3 comentarios
Thanks for this manual.
Would you have the chance to add a photo of the machine without the cover on? My idea is to be able to see what is easily accessible in order to answer some other users' questions such as this one: Could I replace the hard drive with an SSD
dauffret - Contestar
I believe the "hex screwdriver" is not the correct tool required...I believe it's the Torx screwdriver that would be the correct tool.
David Briggman - Contestar
Not sure if the description has been updated since the 07/30/17 comment but the required tool is a T5 Torx screwdriver that is mentioned in the ‘Tools’ section…and they are not very common!
Ken Swanston - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 4,705
