Introducción
If your Bluetooth module is not working correctly, it may need to be replaced. This guide shows the step-by-step process of removing and/or replacing the blue tooth module in a Lenovo Yoga 2 11'“ 20248. You will need a Phillips head screw driver that corresponds to the screw size listed in the guide.
Qué necesitas
Flip the computer over so the bottom is facing up.
Remove the ten 6mm screws with a T5 Torx security screwdriver.
Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
2 personas más completaron esta guía.
