Introducción
Follow this guide to replace the touchpad in your Lenovo YOGA 730-15IKB. The touchpad is located in front the keyboard and allows you to move the pointer onscreen. If your touchpad is not clicking or not responding to your touch, it might be faulty and in need of replacement. The part number for a replacement touchpad is 5T60Q96439 for the dark gray model and 5T60Q96460 for the silver model.
Qué necesitas
Flip the laptop over so you can see the underside.
Remove the ten 7mm T5 Torx screws.
Pull up on the black tab on the touchpad cable connector.
The ribbon cable should easily pull out of the connector.
2 personas más completaron esta guía.
