Saltar al contenido principal
Lenovo Y70-70 Touch Fan Replacement
Qué necesitas
  1. Lenovo Y70-70 Touch Fan Replacement, Back Cover: paso 1, imagen 1 de 1
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. Lenovo Y70-70 Touch Fan Replacement: paso 2, imagen 1 de 1
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  3. Lenovo Y70-70 Touch Fan Replacement, Fan: paso 3, imagen 1 de 1
    • Using the Phillips #0 screwdriver, remove the three screws connecting the fan to the device.
  4. Lenovo Y70-70 Touch Fan Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using a pair of blunt tweezers, disconnect the fan from the motherboard.
    • Remove the fan from the device.
Conclusión
Un comentario
What kind of fan is that?
I need to know what to order for replacement.
vlastimil.beno - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 391
