Saltar al contenido principal
Lenovo Y520-15IKBN Display Replacement
Qué necesitas
  1. Lenovo Y520-15IKBN Display Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the four 4 mm Phillips #00 screws securing the battery.
  2. Lenovo Y520-15IKBN Display Replacement: paso 2, imagen 1 de 2 Lenovo Y520-15IKBN Display Replacement: paso 2, imagen 2 de 2
    • Disconnect the battery connector by pulling the battery cable directly out of its port, toward the battery.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • If necessary, apply force and slowly wiggle the connector out of its socket. It should work its way out slowly.
  3. Lenovo Y520-15IKBN Display Replacement: paso 3, imagen 1 de 1
    • Lift the battery up and out of the chassis.
  4. Lenovo Y520-15IKBN Display Replacement, Display: paso 4, imagen 1 de 1
    • Use an opening tool to pry off the display bezel.
  5. Lenovo Y520-15IKBN Display Replacement: paso 5, imagen 1 de 1
    • Remove the four 4 mm screws with a Phillips #1 screwdriver.
  6. Lenovo Y520-15IKBN Display Replacement: paso 6, imagen 1 de 1
    • Flip up the gate on the display ribbon cable, and pull it directly out of its port.
    • Remove the display from the computer.
Conclusión
Mark A Clement
Miembro Desde 02/15/22
97 Reputación
1 Guía escrita
Equipo
Comm 260 Team 15 Miembro de Comm 260 Team 15
Community
1 Miembro
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 35
Todo El Tiempo: 1,213
