Saltar al contenido principal
Lenovo Y50-70 Touch Trackpad Replacement
Qué necesitas
  1. Lenovo Y50-70 Touch Trackpad Replacement, Trackpad: paso 1, imagen 1 de 3 Lenovo Y50-70 Touch Trackpad Replacement, Trackpad: paso 1, imagen 2 de 3 Lenovo Y50-70 Touch Trackpad Replacement, Trackpad: paso 1, imagen 3 de 3
    • Use a Phillips #1 screwdriver to unscrew and remove the ten 6 mm screws on the back of the laptop.
    • Grab and pull off the back.
  2. Lenovo Y50-70 Touch Trackpad Replacement: paso 2, imagen 1 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 2, imagen 2 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 2, imagen 3 de 3
    • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws that secure the battery.
    • Grab the battery cable and gently pull it free from the cable connector.
    • Remove the battery from the laptop.
  3. Lenovo Y50-70 Touch Trackpad Replacement: paso 3, imagen 1 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 3, imagen 2 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 3, imagen 3 de 3
    • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws that secure the hard drive.
    • Grab the marked cable attached to the hard drive, and gently pull to unplug.
    • Remove the hard drive from the laptop.
  4. Lenovo Y50-70 Touch Trackpad Replacement: paso 4, imagen 1 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 4, imagen 2 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 4, imagen 3 de 3
    • Grab marked cables and pull them out from their plug-in.
  5. Lenovo Y50-70 Touch Trackpad Replacement: paso 5, imagen 1 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 5, imagen 2 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 5, imagen 3 de 3
    • Grab the top set of marked cables and pull up to remove them.
    • Grab the lower marked cable and pull it out from the plug.
  6. Lenovo Y50-70 Touch Trackpad Replacement: paso 6, imagen 1 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 6, imagen 2 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 6, imagen 3 de 3
    • Grab marked cables and pull up to unplug.
  7. Lenovo Y50-70 Touch Trackpad Replacement: paso 7, imagen 1 de 2 Lenovo Y50-70 Touch Trackpad Replacement: paso 7, imagen 2 de 2
    • Grab the marked cable and pull out to unplug.
  8. Lenovo Y50-70 Touch Trackpad Replacement: paso 8, imagen 1 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 8, imagen 2 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 8, imagen 3 de 3
    • Grab the black tab on top of the cable and pull up to unplug.
  9. Lenovo Y50-70 Touch Trackpad Replacement: paso 9, imagen 1 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 9, imagen 2 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 9, imagen 3 de 3
    • Lift the black tab on top of the marked cable.
    • Grab the colored tab on the cable and pull to remove the cable.
  10. Lenovo Y50-70 Touch Trackpad Replacement: paso 10, imagen 1 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 10, imagen 2 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 10, imagen 3 de 3
  11. Lenovo Y50-70 Touch Trackpad Replacement: paso 11, imagen 1 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 11, imagen 2 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 11, imagen 3 de 3
  12. Lenovo Y50-70 Touch Trackpad Replacement: paso 12, imagen 1 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 12, imagen 2 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 12, imagen 3 de 3
    • Lift the black tab on top of the marked cables.
    • Grab the colored tab on the cables and pull to remove the cables.
  13. Lenovo Y50-70 Touch Trackpad Replacement: paso 13, imagen 1 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 13, imagen 2 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 13, imagen 3 de 3
    • Carefully remove the yellow tape on top of the cable.
  14. Lenovo Y50-70 Touch Trackpad Replacement: paso 14, imagen 1 de 2 Lenovo Y50-70 Touch Trackpad Replacement: paso 14, imagen 2 de 2
    • Use a Phillips #1 screwdriver to unscrew and remove the six 7 mm screws from the heat sink.
    • Grab and lift the heatsink off the motherboard.
  15. Lenovo Y50-70 Touch Trackpad Replacement: paso 15, imagen 1 de 2 Lenovo Y50-70 Touch Trackpad Replacement: paso 15, imagen 2 de 2
    • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws marked with red circles on the motherboard.
    • Grab and lift the motherboard up and out from the laptop.
  16. Lenovo Y50-70 Touch Trackpad Replacement: paso 16, imagen 1 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 16, imagen 2 de 3 Lenovo Y50-70 Touch Trackpad Replacement: paso 16, imagen 3 de 3
    • Use a Phillips #1 screwdriver to unscrew and remove the two 6 mm screws at the top of the trackpad.
    • Push on the marked clips at the top of the trackpad.
    • Then, when undone from clips, lift the trackpad out from the laptop.
Conclusión
Ryan McCann
Miembro Desde 04/12/22
305 Reputación
1 Guía escrita
Equipo
IUPUI, Team 6-6, Beck Spring 2022 Miembro de IUPUI, Team 6-6, Beck Spring 2022
IUPUI-BECK-S22S6G6
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 616
