Saltar al contenido principal
Lenovo Y50-70 Touch Motherboard Replacement
Qué necesitas
  1. Lenovo Y50-70 Touch Motherboard Replacement, Motherboard: paso 1, imagen 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement, Motherboard: paso 1, imagen 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement, Motherboard: paso 1, imagen 3 de 3
    • Use a Phillips #1 screwdriver to unscrew and remove the ten 6 mm screws on the back of the laptop.
    • Grab and pull off the back.
  2. Lenovo Y50-70 Touch Motherboard Replacement: paso 2, imagen 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 2, imagen 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 2, imagen 3 de 3
    • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws that secure the battery.
    • Grab the battery cable and gently pull it free from the cable connector.
    • Remove the battery.
  3. Lenovo Y50-70 Touch Motherboard Replacement: paso 3, imagen 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 3, imagen 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 3, imagen 3 de 3
    • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws that secure the hard drive.
    • Grab the marked cable attached to the hard drive, and gently pull to unplug.
    • Remove the hard drive from the laptop.
  4. Lenovo Y50-70 Touch Motherboard Replacement: paso 4, imagen 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 4, imagen 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 4, imagen 3 de 3
    • Grab marked cables and pull them out from their plug-in.
  5. Lenovo Y50-70 Touch Motherboard Replacement: paso 5, imagen 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 5, imagen 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 5, imagen 3 de 3
    • Grab the top set of marked cables and pull up to remove them.
    • Grab the lower marked cable and pull it out from their plug.
  6. Lenovo Y50-70 Touch Motherboard Replacement: paso 6, imagen 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 6, imagen 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 6, imagen 3 de 3
    • Grab marked cables and pull up to unplug.
  7. Lenovo Y50-70 Touch Motherboard Replacement: paso 7, imagen 1 de 2 Lenovo Y50-70 Touch Motherboard Replacement: paso 7, imagen 2 de 2
    • Grab marked cables and pull out to unplug.
  8. Lenovo Y50-70 Touch Motherboard Replacement: paso 8, imagen 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 8, imagen 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 8, imagen 3 de 3
    • Grab the black tab on top of the cable and pull up to unplug.
  9. Lenovo Y50-70 Touch Motherboard Replacement: paso 9, imagen 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 9, imagen 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 9, imagen 3 de 3
    • Lift the black tab on top of the marked cable.
    • Grab the colored tab on the cable and pull to remove the cable.
  10. Lenovo Y50-70 Touch Motherboard Replacement: paso 10, imagen 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 10, imagen 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 10, imagen 3 de 3
  11. Lenovo Y50-70 Touch Motherboard Replacement: paso 11, imagen 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 11, imagen 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 11, imagen 3 de 3
  12. Lenovo Y50-70 Touch Motherboard Replacement: paso 12, imagen 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 12, imagen 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 12, imagen 3 de 3
    • Lift the black tab on top of the marked cables.
    • Grab the colored tab on the cables and pull to remove the cables.
  13. Lenovo Y50-70 Touch Motherboard Replacement: paso 13, imagen 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 13, imagen 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 13, imagen 3 de 3
    • Use a Phillips #1 screwdriver to unscrew and remove the six 7 mm screws from the heat sink.
    • Grab and lift the heatsink off the motherboard.
  14. Lenovo Y50-70 Touch Motherboard Replacement: paso 14, imagen 1 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 14, imagen 2 de 3 Lenovo Y50-70 Touch Motherboard Replacement: paso 14, imagen 3 de 3
    • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws marked with red circles on the motherboard.
    • Grab and lift the motherboard up and out from the laptop.
Conclusión
3 personas más completaron esta guía.
Equipo
IUPUI, Team 6-6, Beck Spring 2022 Miembro de IUPUI, Team 6-6, Beck Spring 2022
IUPUI-BECK-S22S6G6
4 Miembros
3 Guías creadas
Un comentario
Attempting this tomorrow soldiers, wish me luck o7
j.c.glaab - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 23
Todo El Tiempo: 1,187
