Saltar al contenido principal
Lenovo Y50-70 Touch Fan Replacement
Qué necesitas
  1. Lenovo Y50-70 Touch Fan Replacement, Back: paso 1, imagen 1 de 2 Lenovo Y50-70 Touch Fan Replacement, Back: paso 1, imagen 2 de 2
    • Remove all twelve 6 mm screws from the back of the laptop using a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
    • Make sure to turn off the computer first!
  2. Lenovo Y50-70 Touch Fan Replacement: paso 2, imagen 1 de 2 Lenovo Y50-70 Touch Fan Replacement: paso 2, imagen 2 de 2
    • Gently pull the back cover off the laptop. It should come off easily.
  3. Lenovo Y50-70 Touch Fan Replacement, Fan: paso 3, imagen 1 de 2 Lenovo Y50-70 Touch Fan Replacement, Fan: paso 3, imagen 2 de 2
    • Remove the three 3.5 mm screws from the fan with a Philips #1 screwdriver.
  4. Lenovo Y50-70 Touch Fan Replacement: paso 4, imagen 1 de 3 Lenovo Y50-70 Touch Fan Replacement: paso 4, imagen 2 de 3 Lenovo Y50-70 Touch Fan Replacement: paso 4, imagen 3 de 3
    • Pull the wire tabs up one at a time to separate them from the motherboard.
    • Do not pull too hard on the wire tabs. It may damage the connection between the wires and motherboard.
  5. Lenovo Y50-70 Touch Fan Replacement: paso 5, imagen 1 de 3 Lenovo Y50-70 Touch Fan Replacement: paso 5, imagen 2 de 3 Lenovo Y50-70 Touch Fan Replacement: paso 5, imagen 3 de 3
    • Remove the black and white antenna cables from the wireless card.
    • Do not pull too hard on the antenna cables, as it might damage the connection to the wireless card.
  6. Lenovo Y50-70 Touch Fan Replacement: paso 6, imagen 1 de 3 Lenovo Y50-70 Touch Fan Replacement: paso 6, imagen 2 de 3 Lenovo Y50-70 Touch Fan Replacement: paso 6, imagen 3 de 3
    • Lift up the fan slightly.
    • Gather the antenna cables(black and white) and speaker wires (red, black, blue, and white). Carefully move them away from the fan.
  7. Lenovo Y50-70 Touch Fan Replacement: paso 7, imagen 1 de 2 Lenovo Y50-70 Touch Fan Replacement: paso 7, imagen 2 de 2
    • Lift the fan off of the laptop.
Conclusión
8 personas más completaron esta guía.
Vivian
Miembro Desde 01/21/15
351 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 18-1, Maness Winter 2015 Miembro de Cal Poly, Team 18-1, Maness Winter 2015
CPSU-MANESS-W15S18G1
Miembros de 5
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 35
Todo El Tiempo: 9,435
