Saltar al contenido principal
Lenovo Y50 Touch RAM Replacement
Qué necesitas
  1. Lenovo Y50 Touch RAM Replacement, RAM: paso 1, imagen 1 de 2 Lenovo Y50 Touch RAM Replacement, RAM: paso 1, imagen 2 de 2
    • Place laptop on a flat surface with the back cover facing up.
    • Remove all twelve 6 mm long screws on the back of the laptop using a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
  2. Lenovo Y50 Touch RAM Replacement: paso 2, imagen 1 de 2 Lenovo Y50 Touch RAM Replacement: paso 2, imagen 2 de 2
    • Gently pull off the back cover of the laptop. It should come off easily.
  3. Lenovo Y50 Touch RAM Replacement, Locate the RAM: paso 3, imagen 1 de 1
    • The RAM should be located at the indicated area inside the laptop.
  4. Lenovo Y50 Touch RAM Replacement, Unclamp the RAM: paso 4, imagen 1 de 2 Lenovo Y50 Touch RAM Replacement, Unclamp the RAM: paso 4, imagen 2 de 2
    • Release the clamps securing the RAM by pushing each clamp away from the RAM.
    • Once the clamps are released, the RAM should be facing outward at an angle.
  5. Lenovo Y50 Touch RAM Replacement, Remove the RAM: paso 5, imagen 1 de 3 Lenovo Y50 Touch RAM Replacement, Remove the RAM: paso 5, imagen 2 de 3 Lenovo Y50 Touch RAM Replacement, Remove the RAM: paso 5, imagen 3 de 3
    • Gently unplug the RAM from its port.
    • Do not bend or drop the RAM, as this can affect its function.
    • You can replace up to two RAM sticks for this laptop. Just repeat step 4 for the second RAM port.
    • Pay attention to the arrangement of the pins on the RAM. When replacing the RAM, make sure the pins line up with the pins on the RAM port.
Conclusión
9 personas más completaron esta guía.
Andrew Tran
Miembro Desde 01/21/15
820 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 18-1, Maness Winter 2015 Miembro de Cal Poly, Team 18-1, Maness Winter 2015
CPSU-MANESS-W15S18G1
Miembros de 5
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 27
Todo El Tiempo: 5,333
