Saltar al contenido principal
Introducción
This guide will document the process of upgrading or replacing memory in a Lenovo X200 laptop or tablet.
  1. 1. Unscrew the two phillips #1 size screws that hold the panel to access the two memory modules.
    • 1. Unscrew the two phillips #1 size screws that hold the panel to access the two memory modules.
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. 2. Remove the panel to access the memory modules.
    • 2. Remove the panel to access the memory modules.
  4. Note: If only one DIMM is used on the computer, the card must be installed in SLOT-0 ( a ), not in SLOT-1 ( b ).
    • Note: If only one DIMM is used on the computer, the card must be installed in SLOT-0 ( a ), not in SLOT-1 ( b ).
    • Remove DIMM by gently spreading the socket connectors up and down as shown in the direction of the arrows and pull the DIMM out.
    • Insert the notched end of the DIMM into the socket.
    • Press the DIMM firmly, and pivot it until it snaps into the place.
    • Make sure that it is firmly fixed in the slot and does not move easily.
Conclusión
4 personas más completaron esta guía.
James Finch
Miembro Desde 14/10/17
1,303 Reputación
11 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 166
