Saltar al contenido principal
Lenovo Vibe Z2 Pro Battery Replacement
Qué necesitas
  1. Lenovo Vibe Z2 Pro Battery Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: paso 1, imagen 1 de 2 Lenovo Vibe Z2 Pro Battery Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: paso 1, imagen 2 de 2
    • Remove the 4.9 mm torx head screws located on the camera plate on the back of the phone
  2. Lenovo Vibe Z2 Pro Battery Replacement: paso 2, imagen 1 de 1
    • Remove the 3.65 mm Torx head screws at the bottom of the phone.
  3. Lenovo Vibe Z2 Pro Battery Replacement: paso 3, imagen 1 de 2 Lenovo Vibe Z2 Pro Battery Replacement: paso 3, imagen 2 de 2
    • Remove the SIM card tray by pushing a pin into the hole on the side of the phone.
  4. Lenovo Vibe Z2 Pro Battery Replacement: paso 4, imagen 1 de 2 Lenovo Vibe Z2 Pro Battery Replacement: paso 4, imagen 2 de 2
    • Push the Spudger along the gap between the phone and the backplate to separate them.
  5. Lenovo Vibe Z2 Pro Battery Replacement: paso 5, imagen 1 de 1
    • Carefully pull the backplate away from the phone.
  6. Lenovo Vibe Z2 Pro Battery Replacement, Battery: paso 6, imagen 1 de 2 Lenovo Vibe Z2 Pro Battery Replacement, Battery: paso 6, imagen 2 de 2
    • Peel away protective the film using your hands.
  7. Lenovo Vibe Z2 Pro Battery Replacement: paso 7, imagen 1 de 2 Lenovo Vibe Z2 Pro Battery Replacement: paso 7, imagen 2 de 2
    • Remove any adhesive strips holding the battery in place gently using a fingernail or spudger.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
  8. Lenovo Vibe Z2 Pro Battery Replacement: paso 8, imagen 1 de 1
    • Disconnect the orange battery ribbon cable by gently lifting with a spudger.
  9. Lenovo Vibe Z2 Pro Battery Replacement: paso 9, imagen 1 de 3 Lenovo Vibe Z2 Pro Battery Replacement: paso 9, imagen 2 de 3 Lenovo Vibe Z2 Pro Battery Replacement: paso 9, imagen 3 de 3
    • Insert a fingernail or spudger into either side of the battery and lift upward.
    • Remove the battery from phone.
Conclusión
4 personas más completaron esta guía.
Equipo
USF Tampa, Team 18-3, Blackwell Fall 2016 Miembro de USF Tampa, Team 18-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G3
4 Miembros
12 Guías creadas
2 comentarios
Where to buy such battery?
Damir Dominko - Contestar
wala pa po ba dito s pinas ng bl230?
eduardo santos - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 3,354
