Saltar al contenido principal
Lenovo V14-ADA Battery Replacement
Qué necesitas
  1. Lenovo V14-ADA Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • Turn off the laptop.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop upside down.
  2. Lenovo V14-ADA Battery Replacement: paso 2, imagen 1 de 1
    • Remove all ten 5 mm screws from the back panel using a JIS #0 screwdriver.
  3. Lenovo V14-ADA Battery Replacement: paso 3, imagen 1 de 2 Lenovo V14-ADA Battery Replacement: paso 3, imagen 2 de 2
    • Place the Jimmy in the small crack between the back panel and the keyboard and push down.
    • Repeat this until the panel pops off.
  4. Lenovo V14-ADA Battery Replacement, Battery: paso 4, imagen 1 de 2 Lenovo V14-ADA Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Remove the four 3 mm screws surrounding the battery using a JIS #0 screwdriver.
    • Slightly pull on the black wire connector to unplug the battery.
    • Lift up the battery to remove it from the laptop.
Conclusión
Samaya Roukoz
Miembro Desde 03/19/24
253 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 7
Todo El Tiempo: 44
