Saltar al contenido principal
Lenovo Touch Y70-70 RAM Replacement
Qué necesitas
  1. Lenovo Touch Y70-70 RAM Replacement, Back Cover: paso 1, imagen 1 de 1
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. Lenovo Touch Y70-70 RAM Replacement: paso 2, imagen 1 de 1
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  3. Lenovo Touch Y70-70 RAM Replacement, RAM: paso 3, imagen 1 de 2 Lenovo Touch Y70-70 RAM Replacement, RAM: paso 3, imagen 2 de 2
    • Use your fingers or two of the blue Opening Tools to lightly pull the tabs away from the RAM to free the first stick.
    • Remove the first stick and and do the same thing to the second RAM stick.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 302
