Saltar al contenido principal
Lenovo Touch Y70-70 Motherboard Replacement
Qué necesitas
  1. Lenovo Touch Y70-70 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Flip the device so that the back cover is facing you.
    • Using the Phillips #0 screwdriver, remove 14 screws from the back of the device.
  2. Lenovo Touch Y70-70 Motherboard Replacement: paso 2, imagen 1 de 3 Lenovo Touch Y70-70 Motherboard Replacement: paso 2, imagen 2 de 3 Lenovo Touch Y70-70 Motherboard Replacement: paso 2, imagen 3 de 3
    • Using the Phillips #0 screwdriver, remove the three screws holding down the battery.
  3. Lenovo Touch Y70-70 Motherboard Replacement: paso 3, imagen 1 de 2 Lenovo Touch Y70-70 Motherboard Replacement: paso 3, imagen 2 de 2
    • Using the Phillips #0 screwdriver, remove the metal reinforcement by removing the three screws.
  4. Lenovo Touch Y70-70 Motherboard Replacement: paso 4, imagen 1 de 3 Lenovo Touch Y70-70 Motherboard Replacement: paso 4, imagen 2 de 3 Lenovo Touch Y70-70 Motherboard Replacement: paso 4, imagen 3 de 3
    • Using the Phillips #0 screwdriver, carefully remove the three screws holding down the fan.
    • Detach the cables connecting the fan to the motherboard.
  5. Lenovo Touch Y70-70 Motherboard Replacement: paso 5, imagen 1 de 2 Lenovo Touch Y70-70 Motherboard Replacement: paso 5, imagen 2 de 2
    • Using the Phillips #0 screwdriver, remove the six screws holding down the cooling unit.
  6. Lenovo Touch Y70-70 Motherboard Replacement: paso 6, imagen 1 de 2 Lenovo Touch Y70-70 Motherboard Replacement: paso 6, imagen 2 de 2
    • Remove the Ethernet port by unscrewing the two screws holding it down.
  7. Lenovo Touch Y70-70 Motherboard Replacement: paso 7, imagen 1 de 2 Lenovo Touch Y70-70 Motherboard Replacement: paso 7, imagen 2 de 2
    • Unplug the various cables attached to the motherboard using your fingers carefully.
    • Detach the cables using your fingers.
  8. Lenovo Touch Y70-70 Motherboard Replacement: paso 8, imagen 1 de 3 Lenovo Touch Y70-70 Motherboard Replacement: paso 8, imagen 2 de 3 Lenovo Touch Y70-70 Motherboard Replacement: paso 8, imagen 3 de 3
    • Finally, remove the six screws holding down the motherboard.
    • Remove the motherboard from the laptop.
Conclusión
Equipo
IUPUI, Team S2-G5, Harley Fall 2019 Miembro de IUPUI, Team S2-G5, Harley Fall 2019
IUPUI-HARLEY-F19S2G5
2 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 977
