Saltar al contenido principal
Lenovo Touch Y70-70 Hard Drive Replacement
Qué necesitas
  1. Lenovo Touch Y70-70 Hard Drive Replacement, Back Cover: paso 1, imagen 1 de 1
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. Lenovo Touch Y70-70 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  3. Lenovo Touch Y70-70 Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 1
    • Use the Phillips #0 screwdriver to unscrew the four screws.
  4. Lenovo Touch Y70-70 Hard Drive Replacement: paso 4, imagen 1 de 1
    • Disconnect the hard drive from the motherboard.
  5. Lenovo Touch Y70-70 Hard Drive Replacement: paso 5, imagen 1 de 1
    • Use the Phillips #0 screwdriver to unscrew the four screws on the sides of the hard drive frame.
    • Remove the hard drive from the frame.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 26
Todo El Tiempo: 2,587
