Saltar al contenido principal
Lenovo Thinkpad x230 Battery Replacement
Qué necesitas
  1. Lenovo Thinkpad x230 Battery Replacement, Preparations: paso 1, imagen 1 de 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
  2. Lenovo Thinkpad x230 Battery Replacement, Locate the battery: paso 2, imagen 1 de 1
    • Flip the computer upside down.
    • The red rectangle shows the location of the battery.
  3. Lenovo Thinkpad x230 Battery Replacement, Unlock the left switch: paso 3, imagen 1 de 3 Lenovo Thinkpad x230 Battery Replacement, Unlock the left switch: paso 3, imagen 2 de 3 Lenovo Thinkpad x230 Battery Replacement, Unlock the left switch: paso 3, imagen 3 de 3
    • Locate the two switches that lock the battery. Push the left-hand switch outward into the "unlocked" position.
  4. Lenovo Thinkpad x230 Battery Replacement, Remove the battery: paso 4, imagen 1 de 3 Lenovo Thinkpad x230 Battery Replacement, Remove the battery: paso 4, imagen 2 de 3 Lenovo Thinkpad x230 Battery Replacement, Remove the battery: paso 4, imagen 3 de 3
    • Now push and hold the right clip to the right while using your other hand to gently slide the battery away from the computer.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
4 personas más completaron esta guía.
Johannes
Miembro Desde 02/25/14
1,061 Reputación
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 17
Ultimos 30 días: 99
Todo El Tiempo: 6,500
