Saltar al contenido principal
Lenovo Thinkpad X240 RAM Replacement
Qué necesitas
  1. Lenovo Thinkpad X240 RAM Replacement, RAM: paso 1, imagen 1 de 1
    • Flip the laptop up side down as shown in the photo.
  2. Lenovo Thinkpad X240 RAM Replacement: paso 2, imagen 1 de 2 Lenovo Thinkpad X240 RAM Replacement: paso 2, imagen 2 de 2
    • Remove the 8 0.2mm Phillips screws connecting the back cover to the laptop.
  3. Lenovo Thinkpad X240 RAM Replacement: paso 3, imagen 1 de 1
    • Remove the back cover using the opening tools.
    • Gently use the plastic opening tools to prevent scratching your device.
  4. Lenovo Thinkpad X240 RAM Replacement: paso 4, imagen 1 de 2 Lenovo Thinkpad X240 RAM Replacement: paso 4, imagen 2 de 2
    • Remove the RAM stick by carefully popping its holders out of place.
Conclusión
6 personas más completaron esta guía.
2 comentarios
Does this Thinkpad really have only one RAM slot? Or is there another one on the back of the board (i.e. under the keyboard)?
Sebastian Swirski - Contestar
Would I be able to add a 16gb ram stick in it? Even though the highest spec config that the laptop ships with is only 8gb?
Mahir Max - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 31
Todo El Tiempo: 4,657
