Saltar al contenido principal
Lenovo Thinkpad X220 Battery Replacement
Qué necesitas
  1. Lenovo Thinkpad X220 Battery Replacement, Battery: paso 1, imagen 1 de 3 Lenovo Thinkpad X220 Battery Replacement, Battery: paso 1, imagen 2 de 3 Lenovo Thinkpad X220 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Locate the two switches that lock the battery.
    • Then push the left switch outward into the "unlocked" position.
    • This switch will remain in the unlocked position.
  2. Lenovo Thinkpad X220 Battery Replacement: paso 2, imagen 1 de 2 Lenovo Thinkpad X220 Battery Replacement: paso 2, imagen 2 de 2
    • Now push and hold the right switch to the right while using the other hand to gently slide the battery upwards out of the laptop.
  3. Lenovo Thinkpad X220 Battery Replacement: paso 3, imagen 1 de 2 Lenovo Thinkpad X220 Battery Replacement: paso 3, imagen 2 de 2
    • This is a rechargeable Li-Ion battery that has a capacity of 4400 mAh, if you have the 6 cell model.
    • The 4 or 9 cell model has different ratings.
Conclusión
To reassemble your device, follow these instructions in reverse order. Don't forget to switch the left switch back into the locked position.
4 personas más completaron esta guía.
Nils Eymer
Miembro Desde 10/24/16
934 Reputación
2 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 86
Todo El Tiempo: 4,595
