Saltar al contenido principal
Lenovo Thinkpad X201 Tablet RAM Replacement
Qué necesitas
  1. Lenovo Thinkpad X201 Tablet RAM Replacement, RAM: paso 1, imagen 1 de 1
    • Remove the battery by sliding forward the switch here.
    • For more info on how to remove the battery, refer to battery replacement guide.
  2. Lenovo Thinkpad X201 Tablet RAM Replacement: paso 2, imagen 1 de 1
    • The RAM is the small square component on the back. Unscrew all screws using a diamond head screw.
    • There are only two screws to remove as circled here.
    • The screw head used here is a JIS J00 Driver.
  3. Lenovo Thinkpad X201 Tablet RAM Replacement: paso 3, imagen 1 de 1
    • On the edges of the RAM components, push each switch to the side.
    • The RAM chip should pop up on its own once you push each side outwards.
  4. Lenovo Thinkpad X201 Tablet RAM Replacement: paso 4, imagen 1 de 2 Lenovo Thinkpad X201 Tablet RAM Replacement: paso 4, imagen 2 de 2
    • The RAM chip should pop up on its own once the sides are pushed outwards.
    • Gently pull on the RAM to remove.
  5. Lenovo Thinkpad X201 Tablet RAM Replacement: paso 5, imagen 1 de 1
    • Remove the RAM from the device.
Conclusión
2 personas más completaron esta guía.
Peter Gachuki
Miembro Desde 03/26/18
642 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 1,038
