Saltar al contenido principal
Lenovo Thinkpad X201 Tablet LCD Replacement
Qué necesitas
  1. Lenovo Thinkpad X201 Tablet LCD Replacement, LCD: paso 1, imagen 1 de 1
    • First you push the lock button on the back of the computer from lock to unlock
  2. Lenovo Thinkpad X201 Tablet LCD Replacement: paso 2, imagen 1 de 1
    • Then you hold it on unlocked and slide the battery pack out
  3. Lenovo Thinkpad X201 Tablet LCD Replacement: paso 3, imagen 1 de 3 Lenovo Thinkpad X201 Tablet LCD Replacement: paso 3, imagen 2 de 3 Lenovo Thinkpad X201 Tablet LCD Replacement: paso 3, imagen 3 de 3
    • remove all screw covers above hinges
  4. Lenovo Thinkpad X201 Tablet LCD Replacement: paso 4, imagen 1 de 2 Lenovo Thinkpad X201 Tablet LCD Replacement: paso 4, imagen 2 de 2
    • Unscrew the screws on the front of the LCD screen
  5. Lenovo Thinkpad X201 Tablet LCD Replacement: paso 5, imagen 1 de 2 Lenovo Thinkpad X201 Tablet LCD Replacement: paso 5, imagen 2 de 2
    • Remove additional two screws near bezel screws plus the single logic board screw in the center
  6. Lenovo Thinkpad X201 Tablet LCD Replacement: paso 6, imagen 1 de 3 Lenovo Thinkpad X201 Tablet LCD Replacement: paso 6, imagen 2 de 3 Lenovo Thinkpad X201 Tablet LCD Replacement: paso 6, imagen 3 de 3
    • Gently pry the LCD cover with a flat head screwdriver, and pivot it over the signal cable near the LCD hinges. Pivot over all four corners
  7. Lenovo Thinkpad X201 Tablet LCD Replacement: paso 7, imagen 1 de 2 Lenovo Thinkpad X201 Tablet LCD Replacement: paso 7, imagen 2 de 2
    • Continue to remove screens in front of the LCD cover, make sure all screws in the front are removed
  8. Lenovo Thinkpad X201 Tablet LCD Replacement: paso 8, imagen 1 de 1
    • Once all screws are removed, remove the LCD Display but gently peeling back line a sticker
Conclusión
2 personas más completaron esta guía.
Peter Gachuki
Miembro Desde 03/26/18
642 Reputación
4 Guías creadas
Equipo
Un comentario
Is there any other screen that can be used?
Darren Lewis - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 43
Todo El Tiempo: 3,164
