Saltar al contenido principal
Lenovo Thinkpad X201 Tablet Keyboard Replacement
Qué necesitas
  1. Lenovo Thinkpad X201 Tablet Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • First you push the lock button on the back of the computer from lock to unlock.
  2. Lenovo Thinkpad X201 Tablet Keyboard Replacement: paso 2, imagen 1 de 1
    • Then you hold it on unlocked and slide the battery pack out.
  3. Lenovo Thinkpad X201 Tablet Keyboard Replacement, Keyboard: paso 3, imagen 1 de 3 Lenovo Thinkpad X201 Tablet Keyboard Replacement, Keyboard: paso 3, imagen 2 de 3 Lenovo Thinkpad X201 Tablet Keyboard Replacement, Keyboard: paso 3, imagen 3 de 3
    • Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them.
  4. Lenovo Thinkpad X201 Tablet Keyboard Replacement: paso 4, imagen 1 de 1
    • Using your fingers push keyboard forward so it is closer to the screen than it was before
  5. Lenovo Thinkpad X201 Tablet Keyboard Replacement: paso 5, imagen 1 de 1
    • Use a flathead screwdriver to gently lift up on the keyboard until it comes off. Make sure you disconnect the ribbon cable from the motherboard before removing the KB completely.
Conclusión
Una persona más ha completado esta guía.
Thomas Donahue
Miembro Desde 03/20/18
474 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team S5-G7, Peak Spring 2018 Miembro de UMass Dartmouth, Team S5-G7, Peak Spring 2018
UMASSD-PEAK-S18S5G7
Miembros de 3
12 Guías creadas
1Guía Comentario
Excellent.. thank you.. I just put on my new keyboard. I appreciated seeing your photos just to make sure I didn’t miss anything.
Andy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 21
Todo El Tiempo: 2,563
