Saltar al contenido principal
Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement
Qué necesitas
  1. Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement, Bottom Panel: paso 1, imagen 1 de 2 Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement, Bottom Panel: paso 1, imagen 2 de 2
    • Unscrew the nine captive screws on the bottom cover of the laptop using a Phillips #1 screwdriver.
    • The screws do not fully come out of the back cover, so there is no need for screw management.
    • There are a few small clips around the edge that you may need to pry at to free them. An opening pick may be helpful for this process.
  2. Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement: paso 2, imagen 1 de 1
    • Lift the back cover up and off of the computer.
  3. Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement, Speakers: paso 3, imagen 1 de 3 Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement, Speakers: paso 3, imagen 2 de 3 Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement, Speakers: paso 3, imagen 3 de 3
    • Carefully unplug the speaker connector by pulling it towards you.
  4. Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement: paso 4, imagen 1 de 2 Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement: paso 4, imagen 2 de 2
    • Remove the two 5 mm screws on each speaker with a Phillips #1 screwdriver.
  5. Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement: paso 5, imagen 1 de 2 Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement: paso 5, imagen 2 de 2
    • Unweave the blue and white wires from underneath the plastic tabs connected to the battery.
  6. Lenovo Thinkpad X1 Carbon 4th Gen Speakers Replacement: paso 6, imagen 1 de 1
    • Lift each speaker up and out from the computer.
Conclusión
Una persona más ha completado esta guía.
Alexander Davis
Miembro Desde 01/23/20
1,114 Reputación
7 Guías creadas
Equipo
Cal Poly, Team S1-G4, White Winter 2020 Miembro de Cal Poly, Team S1-G4, White Winter 2020
CPSU-WHITE-W20S1G4
3 Miembros
19 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 65
Todo El Tiempo: 2,346
