Saltar al contenido principal
Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement
Qué necesitas
  1. Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement, Bottom Panel: paso 1, imagen 1 de 2 Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement, Bottom Panel: paso 1, imagen 2 de 2
    • Unscrew the nine captive screws on the bottom cover of the laptop using a Phillips #1 screwdriver.
    • The screws do not fully come out of the back cover, so there is no need for screw management.
    • There are a few small clips around the edge that you may need to pry at to free them. An opening pick may be helpful for this process.
  2. Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement: paso 2, imagen 1 de 1
    • Lift the back cover up and off of the computer.
  3. Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement, Speakers: paso 3, imagen 1 de 3 Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement, Speakers: paso 3, imagen 2 de 3 Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement, Speakers: paso 3, imagen 3 de 3
    • Carefully unplug the speaker connector by pulling it towards you.
  4. Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement: paso 4, imagen 1 de 2 Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement: paso 4, imagen 2 de 2
    • Remove the two 5 mm screws on each speaker with a Phillips #1 screwdriver.
  5. Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement: paso 5, imagen 1 de 2 Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement: paso 5, imagen 2 de 2
    • Unweave the blue and white wires from underneath the plastic tabs connected to the battery.
  6. Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement: paso 6, imagen 1 de 1
    • Lift each speaker up and out from the computer.
  7. Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement, Lithium Battery: paso 7, imagen 1 de 3 Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement, Lithium Battery: paso 7, imagen 2 de 3 Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement, Lithium Battery: paso 7, imagen 3 de 3
    • Carefully lift the far end of the battery connector with an opening tool facing towards you.
    • Remove the connector by pushing it forward and lifting.
  8. Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement: paso 8, imagen 1 de 2 Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement: paso 8, imagen 2 de 2
    • Remove the central 5 mm screw with a Phillips #1 screwdriver.
  9. Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement: paso 9, imagen 1 de 1
    • Lift the battery up and out of the computer.
  10. Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement, Mouse Pad: paso 10, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove the six 2 mm screws securing the mousepad to the motherboard.
    • Using the plastic opening tool, lift the flap of the ZIF connector up and pull out the ribbon cable connecting the motherboard to the mousepad.
  11. Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement: paso 11, imagen 1 de 2 Lenovo Thinkpad X1 Carbon 4th Gen Mouse Pad Replacement: paso 11, imagen 2 de 2
    • Using the plastic opening tool, tilt and lift the mousepad away from the bottom of the computer.
    • Remove the mousepad.
    • If the mousepad is being fussy, you can also push it out from the keyboard side of the bottom panel.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 20
Todo El Tiempo: 1,288
