Saltar al contenido principal
Lenovo Thinkpad Tablet 1838 Touch Screen Replacement
Qué necesitas
  1. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement, Touch Screen: paso 1, imagen 1 de 1
    • Remove the button with the arrow pointing left.
    • You can do this by putting the spudger underneath the button and pulling up.
  2. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: paso 2, imagen 1 de 1
    • Remove the two 10mm Phillips #00 screws.
  3. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: paso 3, imagen 1 de 1
    • Use an opening tool to pry open and disconnect the screen from the rest of the tablet.
    • Be gentle and work from the bottom of the tablet in counterclockwise direction.
  4. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: paso 4, imagen 1 de 1
    • Open the tablet screen to the left, making sure not to disconnect any of the wires connecting the screen to the tablet.
  5. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: paso 5, imagen 1 de 2 Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: paso 5, imagen 2 de 2
    • Disconnect the ribbon connector by pulling up on the white gate.
    • Then just simply pull the wire to the left to disconnect it.
  6. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: paso 6, imagen 1 de 2 Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: paso 6, imagen 2 de 2
    • Disconnect the last ribbon connector using your fingernails to grip the ends of the connector and gently pull to the left.
    • There might be some tape over the connector that you will have to remove.
  7. Lenovo Thinkpad Tablet 1838 Touch Screen Replacement: paso 7, imagen 1 de 1
    • You have successfully removed the old screen.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 744
