Saltar al contenido principal
Lenovo Thinkpad T450s Keyboard Replacement
Qué necesitas
  1. Lenovo Thinkpad T450s Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Remove the battery by pulling on the two sliding buttons next to the battery.
  2. Lenovo Thinkpad T450s Keyboard Replacement: paso 2, imagen 1 de 2 Lenovo Thinkpad T450s Keyboard Replacement: paso 2, imagen 2 de 2
    • Remove the seven 5mm screws on the back cover using the Phillips #0 screwdriver.
  3. Lenovo Thinkpad T450s Keyboard Replacement: paso 3, imagen 1 de 1
    • Remove the two rubber stoppers from where the battery previously was.
  4. Lenovo Thinkpad T450s Keyboard Replacement: paso 4, imagen 1 de 2 Lenovo Thinkpad T450s Keyboard Replacement: paso 4, imagen 2 de 2
    • Flip the laptop, shift the keyboard upwards by applying force to the two indents on the keyboard.
    • Remove the six 5mm screws that are on the keyboard using the Phillips #0 screwdriver.
    • These screws are located above the left ctrl key, S, F, J, semicolon, and up arrow keys.
  5. Lenovo Thinkpad T450s Keyboard Replacement: paso 5, imagen 1 de 1
    • Lift the keyboard and flip over exposing the connection to the motherboard.
  6. Lenovo Thinkpad T450s Keyboard Replacement: paso 6, imagen 1 de 1
    • Remove the plastic covering and detach touch point and keyboard cable.
Conclusión
3 personas más completaron esta guía.
Nathan Morgan
Miembro Desde 11/11/19
469 Reputación
2 Guías creadas
Equipo
IUPUI, Team S2-G5, Stella Fall 2019 Miembro de IUPUI, Team S2-G5, Stella Fall 2019
IUPUI-STELLA-F19S2G5
3 Miembros
2 Guías creadas
Un comentario
If after replacement your keyboard has some keys clacking, make sure you slid the keyboard all the way back. Even a small amount can make some keys feel weird.
Ivan Veloz - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 29
Ultimos 30 días: 105
Todo El Tiempo: 6,106
