Saltar al contenido principal
Lenovo Thinkpad T450s Fan Replacement
Qué necesitas
  1. Lenovo Thinkpad T450s Fan Replacement, Fan: paso 1, imagen 1 de 1
    • Flip the laptop over so that the bottom is facing up.
    • Unlock the battery by sliding the keys outwards. When unlocked, push the battery forwards to remove.
  2. Lenovo Thinkpad T450s Fan Replacement: paso 2, imagen 1 de 1
    • Unscrew all 3.7 mm Phillips #0 screws from the back of the laptop. Half of them will remain attached to the cover.
    • Lift off the back cover.
  3. Lenovo Thinkpad T450s Fan Replacement: paso 3, imagen 1 de 1
    • Unscrew the four 5 mm Phillips #0 screws that secure the heatsink.
    • The screws will remain attached.
    • The Fan is attached to the heat sink assembly.
  4. Lenovo Thinkpad T450s Fan Replacement: paso 4, imagen 1 de 1
    • Use a plastic opening tool or a nylon spudger to push the fan's bundled cable connector free.
    • Remove the fan and heat sink assembly from the motherboard.
Conclusión
Una persona más ha completado esta guía.
Murphy Derwent
Miembro Desde 04/05/22
130 Reputación
1 Guía escrita
Equipo
IUPUI, Team 2-3, Harley Spring 2022 Miembro de IUPUI, Team 2-3, Harley Spring 2022
IUPUI-HARLEY-S22S2G3
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 33
Todo El Tiempo: 1,302
