Saltar al contenido principal
Lenovo Thinkpad T440s Back Panel Replacement
Qué necesitas
  1. Lenovo Thinkpad T440s Back Panel Replacement, Back Panel: paso 1, imagen 1 de 2 Lenovo Thinkpad T440s Back Panel Replacement, Back Panel: paso 1, imagen 2 de 2
    • Make sure to power down and turn off your device before proceeding with the repair.
    • Flip your laptop over so that the backside is facing you.
  2. Lenovo Thinkpad T440s Back Panel Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
    • Don’t try to force screws which won't come out. They are held in place by a stopper on the reverse side. This will not prevent you from removing the backplate.
  3. Lenovo Thinkpad T440s Back Panel Replacement: paso 3, imagen 1 de 2 Lenovo Thinkpad T440s Back Panel Replacement: paso 3, imagen 2 de 2
    • Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
  4. Lenovo Thinkpad T440s Back Panel Replacement: paso 4, imagen 1 de 1
    • Remove the back panel from the device.
Conclusión
2 personas más completaron esta guía.
Terelle Montalvo
Miembro Desde 10/22/18
1,477 Reputación
8 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 23
Todo El Tiempo: 1,632
