Saltar al contenido principal
Lenovo Thinkpad T440 Keyboard Replacement
Qué necesitas
  1. Herramienta utilizada en este paso:
    • Power down the computer and remove the external battery.
    • Using a small pick tool, dental pick, tweezers, small flat screwdriver, or similar probe, remove the two small rectangular rubber plugs located inside the battery compartment.
    • Locate the two small oval depressions in the keyboard fascia, just below either Ctrl key.
    • Using a flat screwdriver or narrow spudger in the depressions, slide the fascia up towards the hinges about 3mm (0.1 inches). The top edge slips beneath the bezel.
    • This exposes five Phillips screw heads, located in the 3rd and 5th rows of the key area. Remove them.
    • Using a flat screwdriver or small spudger, lift the keyboard up starting near the bottom edge.
    • There are two ribbon cables; the wider is for the keyboard, and the other is for the touchpoint.
    • Disconnect the ribbon cables by flipping up the plastic keeper holding each ribbon in place.
    • Note their alignment and how deeply each ribbon was inserted in its connector. This knowledge will help you when reinserting the new ribbon cables.
    • Remove the keyboard.
Conclusión
John Deters
Miembro Desde 03/28/18
97 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 544
