Saltar al contenido principal
Lenovo Thinkpad T410i Speakers Replacement
Qué necesitas
  1. Lenovo Thinkpad T410i Speakers Replacement, Keyboard: paso 1, imagen 1 de 1
    • Remove the battery.
    • Unfortunately, the battery isn't pictured because our device did not come with a battery at the time of the creation of this guide.
  2. Lenovo Thinkpad T410i Speakers Replacement: paso 2, imagen 1 de 2 Lenovo Thinkpad T410i Speakers Replacement: paso 2, imagen 2 de 2
    • Loosen (do not remove) the 14.0mm screw in the DIMM slot cover with a Phillips #2 screwdriver.
  3. Lenovo Thinkpad T410i Speakers Replacement: paso 3, imagen 1 de 1
    • Pry loose the top left key-covers with a plastic opening tool.
  4. Lenovo Thinkpad T410i Speakers Replacement: paso 4, imagen 1 de 2 Lenovo Thinkpad T410i Speakers Replacement: paso 4, imagen 2 de 2
    • Nudge the plastic tabs around the keyboard using the plastic opening tool while lifting it with a spudger.
    • Ensure all 5 clips are loosened from the front of the keyboard before removing.
  5. Lenovo Thinkpad T410i Speakers Replacement: paso 5, imagen 1 de 1
    • Slowly raise keyboard away from the laptop. A short ribbon must be removed before keyboard is free.
    • Remove the keyboard from the device.
  6. Lenovo Thinkpad T410i Speakers Replacement, Speakers: paso 6, imagen 1 de 1
    • Remove the six 14.0mm screws with a Phillips #0 screwdriver.
    • Remove the three 3.0mm screws with a Phillips #0 screwdriver.
  7. Lenovo Thinkpad T410i Speakers Replacement: paso 7, imagen 1 de 1
    • Snap off the top cover with a plastic opening tool, ensuring that the tabs don't snap back on.
  8. Lenovo Thinkpad T410i Speakers Replacement: paso 8, imagen 1 de 1
    • Lift the top panel off of the device.
    • Lift the panel slowly in order to not damage the orange ribbon cable.
  9. Lenovo Thinkpad T410i Speakers Replacement: paso 9, imagen 1 de 1
    • Detach the ribbon cable as shown in the picture.
  10. Lenovo Thinkpad T410i Speakers Replacement: paso 10, imagen 1 de 2 Lenovo Thinkpad T410i Speakers Replacement: paso 10, imagen 2 de 2
    • Remove the four 3.0mm screws with a Phillips #0 screwdriver.
  11. Lenovo Thinkpad T410i Speakers Replacement: paso 11, imagen 1 de 1
    • Using the Precision Tweezers, remove the speaker cable from the connector.
    • Remove the speaker from the device.
Conclusión
4 personas más completaron esta guía.
Equipo
USF Tampa, Team S1-G2, Thompson Fall 2017 Miembro de USF Tampa, Team S1-G2, Thompson Fall 2017
USFT-THOMPSON-F17S1G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 1,363
