Saltar al contenido principal
Lenovo Thinkpad T410i LCD Screen Replacement
Qué necesitas
  1. Lenovo Thinkpad T410i LCD Screen Replacement, Screen Bezel: paso 1, imagen 1 de 2 Lenovo Thinkpad T410i LCD Screen Replacement, Screen Bezel: paso 1, imagen 2 de 2
    • Use a spudger to remove the plastic covers from the LCD screen.
  2. Lenovo Thinkpad T410i LCD Screen Replacement: paso 2, imagen 1 de 1
    • Remove the two 6.0mm screws on each side using Philips #0 head screwdriver as shown in the picture.
  3. Lenovo Thinkpad T410i LCD Screen Replacement: paso 3, imagen 1 de 1
    • Use a spudger to separate the bezel of the LCD screen.
  4. Lenovo Thinkpad T410i LCD Screen Replacement: paso 4, imagen 1 de 3 Lenovo Thinkpad T410i LCD Screen Replacement: paso 4, imagen 2 de 3 Lenovo Thinkpad T410i LCD Screen Replacement: paso 4, imagen 3 de 3
    • Continue along the edges lifting up and prying off the plastic LCD bezel.
  5. Lenovo Thinkpad T410i LCD Screen Replacement, LCD screen: paso 5, imagen 1 de 2 Lenovo Thinkpad T410i LCD Screen Replacement, LCD screen: paso 5, imagen 2 de 2
    • Use a Philips #0 head screwdriver to remove the two 6.0mm screws from the top corners of the LCD screen.
  6. Lenovo Thinkpad T410i LCD Screen Replacement: paso 6, imagen 1 de 3 Lenovo Thinkpad T410i LCD Screen Replacement: paso 6, imagen 2 de 3 Lenovo Thinkpad T410i LCD Screen Replacement: paso 6, imagen 3 de 3
    • Place the LCD screen safely down on its front.
    • Pulling the screen too far away from the screen may damage delicate ribbon cable.
    • Peel the tape off the ribbon cable's contacts.
    • Carefully detach the ribbon cable from the LCD screen.
    • Poking the golden contacts may easily damage them.
  7. Lenovo Thinkpad T410i LCD Screen Replacement: paso 7, imagen 1 de 1
    • Remove the screen from your device.
Conclusión
3 personas más completaron esta guía.
Harsh Patel
Miembro Desde 10/02/17
287 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S1-G2, Thompson Fall 2017 Miembro de USF Tampa, Team S1-G2, Thompson Fall 2017
USFT-THOMPSON-F17S1G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 11
Todo El Tiempo: 577
