Saltar al contenido principal
Lenovo Thinkpad T410i Keyboard Replacement
Qué necesitas
  1. Lenovo Thinkpad T410i Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Remove the battery.
    • Unfortunately, the battery isn't pictured because our device did not come with a battery at the time of the creation of this guide.
  2. Lenovo Thinkpad T410i Keyboard Replacement: paso 2, imagen 1 de 2 Lenovo Thinkpad T410i Keyboard Replacement: paso 2, imagen 2 de 2
    • Loosen (do not remove) the 14.0mm screw in the DIMM slot cover with a Phillips #2 screwdriver.
  3. Lenovo Thinkpad T410i Keyboard Replacement: paso 3, imagen 1 de 1
    • Pry loose the top left key-covers with a plastic opening tool.
  4. Lenovo Thinkpad T410i Keyboard Replacement: paso 4, imagen 1 de 2 Lenovo Thinkpad T410i Keyboard Replacement: paso 4, imagen 2 de 2
    • Nudge the plastic tabs around the keyboard using the plastic opening tool while lifting it with a spudger.
    • Ensure all 5 clips are loosened from the front of the keyboard before removing.
  5. Lenovo Thinkpad T410i Keyboard Replacement: paso 5, imagen 1 de 1
    • Slowly raise keyboard away from the laptop. A short ribbon must be removed before keyboard is free.
    • Remove the keyboard from the device.
Conclusión
5 personas más completaron esta guía.
Equipo
USF Tampa, Team S1-G2, Thompson Fall 2017 Miembro de USF Tampa, Team S1-G2, Thompson Fall 2017
USFT-THOMPSON-F17S1G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 13
Todo El Tiempo: 908
