Introducción
This guide will help you replace a motherboard step by step. From beginning to end this guide will take you from beginner to expert in easy efficient fashion.
Qué necesitas
Using a plastic opening tool or opening pick, gently pry the screen off.
Once you're able to lift a little bit of the screen away from the tablet, work your way around until screen is separated from tablet. Stop for step two.
Remove the seven, 3mm, Phillips #00 screws attaching motherboard to the back cover.
Una persona más ha completado esta guía.
