Saltar al contenido principal
Lenovo Thinkpad Edge E545 Screen Replacement
Qué necesitas
  1. Lenovo Thinkpad Edge E545 Screen Replacement, Battery: paso 1, imagen 1 de 1
    • First, flip the laptop over as shown in the photo.
    • Make sure device is fully powered down before removing battery.
  2. Lenovo Thinkpad Edge E545 Screen Replacement: paso 2, imagen 1 de 1
    • Below the battery are two small tabs. These function as a lock for the battery.
    • Push the tabs towards each other to release the battery.
  3. Lenovo Thinkpad Edge E545 Screen Replacement: paso 3, imagen 1 de 1
    • Remove the battery from the device.
  4. Lenovo Thinkpad Edge E545 Screen Replacement, Screen: paso 4, imagen 1 de 2 Lenovo Thinkpad Edge E545 Screen Replacement, Screen: paso 4, imagen 2 de 2
    • Then, use the end of a spudger to remove the two screw covers from the top and bottom corners of the display.
  5. Lenovo Thinkpad Edge E545 Screen Replacement: paso 5, imagen 1 de 1
    • Slide your finger underneath the plastic and pry gently to release the clips around the display bezel.
  6. Lenovo Thinkpad Edge E545 Screen Replacement: paso 6, imagen 1 de 2 Lenovo Thinkpad Edge E545 Screen Replacement: paso 6, imagen 2 de 2
    • Lastly, peel up the adhesive tape to unbind the metal retaining bracket on the display cable.
Conclusión
Maria Yepez
Miembro Desde 10/24/18
97 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 598
