Saltar al contenido principal
Lenovo Thinkpad E540 WiFi Card Replacement
Qué necesitas
  1. Lenovo Thinkpad E540 WiFi Card Replacement, Battery: paso 1, imagen 1 de 2 Lenovo Thinkpad E540 WiFi Card Replacement, Battery: paso 1, imagen 2 de 2
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 WiFi Card Replacement: paso 2, imagen 1 de 1
    • Remove the battery.
  3. Lenovo Thinkpad E540 WiFi Card Replacement, WiFi Card: paso 3, imagen 1 de 1
    • Remove the single 1mm Phillips #0 screw holding the small plastic panel in place.
  4. Lenovo Thinkpad E540 WiFi Card Replacement: paso 4, imagen 1 de 1
    • Use a plastic opening tool to remove panel.
  5. Lenovo Thinkpad E540 WiFi Card Replacement: paso 5, imagen 1 de 2 Lenovo Thinkpad E540 WiFi Card Replacement: paso 5, imagen 2 de 2
    • Disconnect the two antenna cables from the wifi card.
    • Remove the single 1mm Phillips #0 screw from the wifi card.
  6. Lenovo Thinkpad E540 WiFi Card Replacement: paso 6, imagen 1 de 1
    • Remove the wifi card by sliding it out.
Conclusión
2 personas más completaron esta guía.
Timothy Sumner
Miembro Desde 02/14/18
1,040 Reputación
8 Guías creadas
Equipo
USF Tampa, Team S2-G5, Nance Spring 2018 Miembro de USF Tampa, Team S2-G5, Nance Spring 2018
USFT-NANCE-S18S2G5
4 Miembros
8 Guías creadas
2 comentarios
Pictures show battery is still connected to laptop.
Monte Christo - Contestar
There appear to be several different wifi cards available, with different PN numbers. Is it necessary to replace with the exact same PN number? Can these wifi cards be upgraded?
Thomas - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 28
Todo El Tiempo: 2,974
