Saltar al contenido principal
Lenovo ThinkPad x120e RAM Replacement
Qué necesitas
  1. Lenovo ThinkPad x120e RAM Replacement, Battery: paso 1, imagen 1 de 2 Lenovo ThinkPad x120e RAM Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the laptop upside down and locate the battery latches under the battery.
    • Place your thumbs on both latches and push the latch inwards.
    • With your thumbs still on the latches, slide the battery out of the laptop.
    • To install a new battery, simply slide the battery back in the slot. Then, check if both battery latches are locked
  2. Lenovo ThinkPad x120e RAM Replacement, Back Cover: paso 2, imagen 1 de 3 Lenovo ThinkPad x120e RAM Replacement, Back Cover: paso 2, imagen 2 de 3 Lenovo ThinkPad x120e RAM Replacement, Back Cover: paso 2, imagen 3 de 3
    • Using the Phillips #0 screwdriver, remove the three 4 mm screws that are securing the bottom cover.
    • Remove the backplate carefully, making sure not to bend the cover.
  3. Lenovo ThinkPad x120e RAM Replacement, RAM: paso 3, imagen 1 de 3 Lenovo ThinkPad x120e RAM Replacement, RAM: paso 3, imagen 2 de 3 Lenovo ThinkPad x120e RAM Replacement, RAM: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Push the two mounting clips on either side of the RAM away from each other.
    • While doing this step, wear an anti-static wrist strap. This will prevent you from generating static that could damage the RAM module.
  4. Lenovo ThinkPad x120e RAM Replacement: paso 4, imagen 1 de 2 Lenovo ThinkPad x120e RAM Replacement: paso 4, imagen 2 de 2
    • The RAM should now be lifting up at an angle.
    • Slide the RAM stick out in the direction the angle is facing.
    • While installing the new RAM stick, push the stick down at an angle and make sure you secure it with the small clips at both sides.
Conclusión
Equipo
UMass Dartmouth, Team 3-4, Sinclaire Fall 2021 Miembro de UMass Dartmouth, Team 3-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G4
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 21
Todo El Tiempo: 317
